Weird check engine light
No. Ok the plugs that i had in my car were heat range 5. I just bought some ngk bkr6es and the car kinda cured, my problem now is that i have a dead cylinder on #3. I can unplug the injector and pull the plug wire and the car runs the same. I did swap injectors though.
The diagnostic system is there for a reason. It is telling you that something is wrong. Until you check for codes you need to stop messing with it. You are wasting money replacing parts without knowing what is wrong.
Then I'm done here.
You have the means to see what the car is tellign you may be wrong and you haven't checked :confused:
If removing fuel from a signal cylinder is not making a change in the way the car is running I'd be doing a compression test and/or leak down test to rule out a mechanical problem... . :|
It's been fixed...too hot of a spark plug and thereon plugs.
