what car are these injectors for ?
nsgk53
94
Sep 28, 2011
lith, Illinois
What car are these injectors for? There pte 780/750 injectors. Bought them for my 2gb eclipse gsx but there to big for the stock fuel rail. was told they were on a 1g 4g63 dsm but everyone i showed them to said they wont work. Would need a aftermarket fuel rail for them to work. Was told after buying them that the injectors could be for a eclipse 420a or a neon srt4. Any suggestions? Numbers on top of them are 6066 and 17113742
Those pte injectors are Rochester Delphi injectors that are designed to fit in a domestic car fuel rail, pte turns them down to fit import rails. It's hard to tell from the pics, but it looks like they haven't been cut down for an import rail. If that is the case, you can either turn the tops down in a lathe, or drill out the holes in your rail.
PTE makes primarily domestic sized injectors, the ends can be cut away with a lathe but I have always found it to be much easier to drill the fuel rail
