what can i use to clean out my stock lower intercooler pieping
water is fine, but for better and faster results use gas. LOL i know its $2.80 a gallon, but just one gallon or so and you should be fine.
oldman said:
This way works, but i personally think that if you can get under the car it is much much easier. I have a hoist, so of course it will be easy for me. But if you could even jack up the front of your car enough to roll underneath of it with a creeper, that is what i recommend! Just unscrew the piping with a screw driver, then i think 3 bolts hold the IC on. First though you have to remove the "splash sheilds" which i think are help on by 2 little plastics screws. Then just have at it! Just my opinion though!!
I used rubbing alcohol to clean out my intercooler once. It took two large bottles @ about $1 a piece, and I wasn't really too happy with the results. If I had to do again, I'd probably use a gallon of gas and let it soak. For IC pipes, gas or alcohol would work, whichever you prefer.
And I don't have to tell you not to smoke while you do this, right? :p
