What can I do about power steering bearing squeak?
All I change on my steering pump was the bearing that the pulley/shaft rides on. Stopped the squeaky noise and has been good ever since. Took the bearing to napa auto parts where they measured it and found the right size bearing which cost me $6.
Was going to change gaskets and all too but it was not in stock or they kept on ordering the wrong parts.
I have been trying to track down a squeak on my son's '96 myself. I used a stethoscope at first and thought it was coming from the tensioner - so I replaced the PS belt and the tensioner bearing (and the tensioner bolt because it was stripped out)..... put it all back together and it still squeaks. So, I removed the new belt and started the car with no power steering belt - and NO squeak. So, I am now assuming it's either the A/C or the power steering bearings? I gave each a spin when the belt was off and couldn't hear any offending noise, but both do have a little bit of 'play' when you try to wiggle the pulleys.
While the belt was out, I gave the new belt and tensioner a light scuff with sandpaper and put the belt back on so it can be driven, and the squeak is still there. It doesn't seem to change pitch or anything when I turn the steering wheel (driving or sitting still), so I am leaning toward it being the A/C pump bearing?
My husband has been working gawdawful hours, so I am trying to get this figured out myself. My son is NOT mechanical at all. My older son is, but he's away at college.
