What assembly lube did everyone use?
I used the thick black moly lube, like the ARP stuff on the bearings and pre-lubed the pistons/rings/bores with ATF, Dextron III :) Per my machinist.
Jay
i used STP that really sticky oil treatment. On all my bearings but arp moly lube on all my studs.
I actually use synthetic grease on the motor and once the motor is fully assembled I prime the whole motor with a drill on the oil pump before attaching the timing belt. Then once the car is together I crank it over for about 20 seconds before I fire it up.
I used the red oil and mtoor oil before when doing rod bearings and such and it is sooo messy compared to grease and as long as you prime the motor before firing I see no prob with using the grease. I have been told however it is not good to assemble turbos with grease though.
Later
I would go with the red line assembly lube. Use ARP moly on the rod and head bolts and pack the oil pump with vasoline. I dont like to use grease in a motor because it its to thick and clogs the oil filter. You can also use the regular lucus oil treatment right out of the bottle. Its nice and thick and wont drain off.
