2G What are these
TreyDaBurna
57
Feb 14, 2013
Las Vegas, Nevada
Cleaning up my engine bay and i find these no freakin clue where they go...one things for sure who ever had this car before me did not take care or it one of these things has a vacuum hose on it...no freakin clue where it needs to be. HELP!!!:banghead:
better pic. hose goes to a tee on turbo and wastegate on one end then who knows where on the other
The black one with the vacuum hoses is the stock boost controller solenoid. I believe the yellow one is a relay? Mine are just hanging there too or you can bolt them back to the inner part of the engine bay.
so where does the other end of the hose go?
what eliminates the need for the stock boost controller because i dnt think theres a aftermaket in here
First picture- Mitsu calls it the "alternator relay". It's basically a backup wire in case the main feed breaks and the box is actually a resistor for the battery light. P/N: MD128752
Search the P/N followed by "dsmtuners" on google and you'll find very knowledgeable members explaining it a bit better. I'm going off memory here.
