0r1landoDSM
- 213
- 0
- Nov 10, 2010
Long Island,
New York
looking for a 2g DSM gs-t or gsx 4g63t
(check them rod bearings)
Typically the 1ga's have the 6 bolt.(90-91) with 3 bolt rear except they switched halfway during the year to the 4 boltIf its a 1st gen, find out if it's a 6 bolt or a 7 bolt, do this by checking the oil pan...i dont remember exactly which means which but i know their should be a protrusion or a dent in the pan which signifies if its a 6 or 7 bolt motor....can somebody else chime in a specify which means which? i dont remember exactly
bypass valve venting to atmosphere... good sign the previous owner didn't really know/care about what he was doing.
92-94 1gbs have the early 7 bolt with the 4 bolt rear
95-98 have the the late 7 bolt
99's have the revised 7 bolt that is "uncrankwalkable".
Typically the 4 bolt 6 bolt is what people look for. And usually if its unspecified by the seller its not swapped.
If a swap is specified here you go just to be safe:How to quickly tell a 6bolt and 7bolt engine apart
I guess its the same concept as a bov. Lols.
and above all else, do not fall for the classic dsm seller conversation:
Seller: As you see its a very clean car.
You: Yeah she is, but what is this oil leak about?
Seller: Oil leak? That's not an oil leak, that's just sweat from the horsepower!
You: Awwwww snap!
