What are a good set of pistons
Inverted540
Jul 28, 2005
Arvada, Colorado
What are a good set of pistons to go with. I am going to be running 28psi in a 6 bolt motor and need a good set of pistons. What do you guys think?
What turbo? You could run 28 psi on a t25, but not much would happen.
Piston wise, if you're going to be running high boost (with a turbo like a 50 trim), I would go with J&E pistons or Wiseco's (both 8.5:1 compression ratios respectively.)
Good luck.
