what all does it take to install camshaft
schultz9008
46
Jul 22, 2009
covington, Indiana
so i was thinking about get camshaft and cam gears, but i wasnt sure what you have to do in order to install these and what will they do for me and exactly how would i benefit from this.
Remove the valve cover, timing belt, and cam caps. Pull stock cams off. If you have assembly lube, liberally coat the lobes and journals of the new cams. Set them in place, and install caps in their original locations. Install timing belt and time engine. If you did not use assembly lube, pour clean oil over the cams before installing the valve cover. It's pretty straightforward once you dig in.
The gears can be removed and installed either on the vehicle, or on the bench.
The cams available for our cars give top end power, at the expense of low end torque. For the best results, larger cams should be installed in a head with port work done.
It will take as long as it takes ;) I hate to give times on things like this because then people start rushing and screw it up. It can take anywhere from 1 1/2 hours to a weekend depending on your level of expertise, experience, problems encountered blah blah blah. Generally it gets done in a day for the first timer.
Couple of links to follow. The first one is missing pics. The second one is more complete.
Articles: 420A-specific - DSM Forums
2GNT.com - Timing_Belt_Replacement
MB
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
