were is the ecu at in the 2G gst
You know just because you're a member of the norcal board doesn't mean you can't access the rest of the site. This question has probably been answered over a hundred times on this site, use the search feature of this board, it's probably the most valuable tool you will ever use on this website.
It should be behind the center console where it meets your dash (just under the head unit by the way, not the easiest to get to but not hard to remove either.)
Honestly some of your posts are in the wrong section. The questions you ask are not norcal specific so you can just post them in the newbie section. And a lot of the questions you asked can be found very easily by searching. Its even made easier with a new search button at the top of the page.
Just like Pac0 said its behind the center console. You will need to pull off the kick panel on both drivers side and passenger side. Once you do that, it will be right there.
