ZenkaiRacerDsM
- 760
- 8
- Nov 8, 2002
Layton,
Utah
Not too long ago I dynoed 374whp on 91 octane at 25psi peak boost. According to the dyno sheet it was knocking at about 6k on up.
I went to the track today for my first ever runs at the track. The first run it knocked the entire run until I hit the brakes trying to get slower then a 13.9 since I didn't have a helmet. Ran a 13.5@88. I didn't notice it was knocking the entire time till I looked at the log.
Second run is after I adjusted timing and lowered the boost a little. According to the log the boost was the same, it just reached that boost later.
Anyways, it was good till 3rd gear where it immediately knocked, i let off then went on again just to knock again.
This is the log from the 2nd run after I adjusted timing. After this run I dropped timing some more in the cells where it lands after I shift into third. Didn't have time to do another run to see its effects, and I didn't have a helmet anyways.
Anyways, just looking for some pointers. My AFR's are between 11.3 and 10.9. I know I really need to wire it in for logging.
Perhaps a short in the wire?
