went to the local 1/8 with the hx40 on 22psi
He did an 1/8 pass how quick was it.......
^^^ nevermind thanks tron! My iPad just plays from the screen here and doesn't show the details
The 2 step was building 10psi and I babied it out the hole and granny shifted. I was happy with the results. Jacks trans and new hg along with more boost it will put me in the low 7's high 6's. Next outing will be on 27-30ish psi.
Nice time for such low boost. The MPH is very low, what backhousing do you have? Definitely crank the boost up north of 30lbs and you should be right around the high 6 low 7 mark which is about mid to high 10s in the quarter.
You should definitely be trapping a little higher, I trapped 91.81 in the 1/8th on 19 psi with my HX40.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
