Welded studs on block question
fwbt
244
4
Dec 31, 2007
Raeford, North Carolina
I have a 4G63 block I'm considering building in to a stroker motor. While removing the front motor mount I found that the casting for the threaded holes for the bolts had been broken off the block. The previous owner had studs welded in to replace the bolts. My question is will this hold up to the stresses of a 2.3L stroker or should I work on finding a new block?
Indeed! I just finished resizing them.
1G 6 bolt. I originally pulled it in '98 for my 90 NT Laser. I didn't know if there was a significant difference between a NT and AWD in the loads held by that mount.
  • Wanted 6 bolt NT water pipe
    • chrisman287
