Weird problem
Dsm304
142
Nov 17, 2011
Mission, Texas
Ok I hace this weird problem just started about an hr ago when I was coming from school well I has going 35mph and all of a sudden the car got heavier and started to sputter like when I have a boost leak and the more gas and boost goes up fine the more itbsputters and everything shakes :confused: so I let go of the gas for like 5 to 7seconds and give it some gas and will run like a champ then at like 40 45mph it will do it again so I do the same process and so on but only happens from 35mph and higher it was weird but I have no idea what it could be any ideas of anything would help guy thanks apreciate the help!
Start off with doing a boost leak test.
Yeah I will and if it is I will be really mad I just fixed 2 boost leaks in the past 2 months! Lmao
Could be fuel related, had similar symptoms with crappy fuel filter and DOA fuel pump on my 1g
I was thinking of that because my fuel pump is kinda noisy at times im guessing its going out already
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
