weird problem
Eclipseturbo4
73
Jan 12, 2007
Cedar Rapids, Iowa
ok well ive tryed to put a cold air intake onto my 96 eclipse gst and it works for a while and then it decides to got to sh*t on me and i just want to know what it might be so i could run the cold air intake. i dont know what im doing wrong.
Try resetting your ECU. Just disconnect the black terminal on you battery for like 2 min. That might help.
As a side note, cold air intakes aren't that great. Usually you end up loosing power. Not to mention the piping heats up (unless it's a plastic pipe) so as the air flows through it is heated before it enters your intake. If you can, get a short ram intake. Those usually perform better and have less issues.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
