Weird...MBC / Guage Help please?
RockSolidGST
151
Mar 23, 2005
Boston, Massachusetts
Ok So i had my guage installed , it was reading around 14-15lbs on stock everything with no controler , Seemed a little high , Got intake , exhaust , downpipe , was reading it was spiking to 18lbs ( still no MBC hooked up ) , Install the MBC Set it , Its reading , and staying at 15lbs.... So the other day i turn the boost up because it almost felt faster without it when it was spiking to 18lbs ( even though i know t25 cuts out at 16lbs )
And i seem to "feel" more power ( no dyno access unfortunatly ) But the gauge is still reading 15lbs , I dont understand , its a tuboXS mbc .... Could the MBC be bad? I know its hooked up right i checked and rechecked it on the vfaq , also had somebody else check it....
Also at 1/2 throttle sometimes there is a little sqeek? strange.. :confused:
Anything thoughts?:thumb:
First don't turn up past 16 psi, on stock fuel system and your t25. Trust me you will regret it :notgood:
On topic though, where do you have your mbc lines hooked up?? Thru the bov line, compressor housing, somewhere else??
My mbc is hooked up threw the bov line , ( i did exactly what vfaq tells you to do ) and the waistgate
I also have walboro 255 , fpr , and a frontmount , so if i wanted , i think i could squueze 1 or 2 psi out of this crap turbo untill i get my new one ( its more for the new one that im worryed about this for )
MBC's should be hooked up to the intake manifold or off the j-pipe/compressor housing. THey should not be tee-d into the bov line it can screw up how your bov is supposed to work, it could open premature and leak your precious boost because the mbc is a bleeder valve.
