1G MBC HELP?:L
dsmBear
387
10
Aug 27, 2012
Carmichael, California
Quick background: So my car 94 gsx 6/4 combo was boosting 14 psi when I got it(stock), no mbc or anything. When I rebuilt the motor and slapped it back in and it only does 9-10 psi idk why so I got an mbc now, and hooked it up and it does infinite boost at the bottom click? ive done a boost leak and smoke test and everything holds, im wanting to run 13-14 psi safley but seems like the boost keeps crawling, btw mhi big 16g turbo (had same issues when oe 14b was on as well)
Anyone? And now after adding a hard uip, to the stock side mount, at first just did 8-9, but now it does 6-7? (This is with out the mbc, as the mbc does infinite boost)
I had the same problem and It was because I hooked it up backwards turns it around and problem whent away
would help if we knew what type of boost controller you got.
I'm familiar with the hallman.
Every post you are dropping more and more psi. Are you sure you did a boost leak test.
