1G Weird backfiring problem (video)
buhay6
1,661
65
Jul 9, 2010
Delisle, SK, Canada
I'm having problems with major back firing after letting off the throttle, where it be just cruising or coming off of boost. It's done a number on turbo's (been through 4 now) already, it took only 2 weeks to wreck my nicely rebuild 14b from Justin. I do have spiky boost condition's, haven't been able to control it since the port job seeing anywhere from 9-17 PSI, get good afrs cruising. Wideband's installed correctly with factory narrowband deleted.
Current mod's
-ported 14b (not relevant)
-tubular O2 w/g dump (not relevant)
-Innovate MTX L1
-BSE (not relevant)
-fidanza flywheel (not relevant)
-southbend clutch (not relevant)
Tested/replaced:
BLT (passed, leaky exhaust valve)
Throttle position sensor replaced
Ignition timing checked
coolant temp sensor replaced
spark plugs replaced ( NGK BPR6ES)
Re-calibrated wideband multiple times
Any other suggestions as to what I should look at next? I've checked everything I could find as possible causes but have got no results!
Started happening after my throttle body rebuild, everything went for shit after that. So I went back and double check everything was set right, found my TPS sensor was slightly out of spec so I changed that, then found the fast idle control valve was totally gone so I replaced that as well, all new seals etc. I kind of wish now that I hadn't have touched it, car had massive boost leaks but pulled like a boss.
I fixed every boost leak I could find system holds 30 PSI very well only leaks a little passed the piston rings and out a leaky exhaust valve over a few min. Intake and SMIC is completely stock.
What about fuel pressure and injectors backfires usually happen and pressure regulator.
I don't think its an injector failure as I've swapped in 2 different sets already, and it didn't change a thing. I do have a Fuellab FPR sitting on the shelf waiting to be installed so guess it wouldn't hurt to rig it in there for now to see. I have no tools for testing the old regulator tho.
Did you say you have a leaky exhaust valve well that's the problem. Always fix obvious problems first .
It shouldn't cause such excessive backfiring tho, plus all the plugs are sooty. I already know its one of the exhaust valves in cylinder 3 so there should be a difference between the plugs no?
*sigh* i was really hoping to keep from spending another cent on this engine because the thrust bearings totally done.......oh well.
Just did a compression test (engine was still warm to the touch), and got the same comp reading I got when I first installed the engine. also just installed a new set of BPR7ES, as there was some irregularities between the 6ES's I was running
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
