kochan99
- 0
- Oct 22, 2005
Wausau,
Wisconsin
I have recently purchased a 99 eclipse GS. It has been in an accident and has been fixed with a new body kit, paint, etc. The only problem I have is that my automatic door locks act weird. When I push the inside button on the drivers side to lock it, it will just lock the drivers side door and nothing will happen on the passenger side. The relay clicks fine under the dash but nothing happens on the passenger side. When I push the buttons to unlock the doors on either door nothing happens. Neither door will unlock and no click from the relay, no movement or any noise whatsoever. I was told when I bought the car that is was the relay that needs to be replaced. And I was also told that there are 2 relays that control the locks and Im guessing that the other relay is the one right next to the one that is clicking. The right relay is the only one that will click and the left one does nothing. What could the possible problems be, I feel I have tested everything and nothing is coming good from this? My car does have an aftermarket python alarm system. You guys are the pros what you think?
