water pump removal and reinstall without removing timing belt?
tfaulk21
153
Aug 28, 2011
Mt. Holly, North Carolina
is there a way to do this? to remove my water pump thats shot without removing my timing belt yeah i know i should do both but my belt is good it was put on around 20k ago and its not dry rotted no scuffs tears or anything looks brand new. i just need to replace my water pump and put my belt back on the alternator crank shaft and water pump. thats it.
Yeah but I don't know what's gonna happen or even how to line up the knotches right i wanna learn just don't know where to start really I checked out the vfaq but only so much you can see on the.phone
That is why you mark everything before pulling the belt off. You also need to make a tool to compress the tensioner on the car if you don't know how to set the tension.
