wastegate
Yes, Paul is correct.
I am opting for the median of these two. A DUAL STAGE MANUAL Boost controller.
This will do the same thing, alowing you to adjust the boost setting with a HI/LO as well, and giving you the conveniance of adjustment from inside the cockpit.
Hahn uses a dual stage for 12psi , then 22psi in second gear. It's GREAT for traction and jumping off the line.
I am going with the turboXS Dual stage MBC, so check that out if you're cheap and simple like me. :thumb:
That depends on what you want... a nifty little digital display with all the bells and whistles (Profec B) or just knobs (Type-S).
It doesn't, you tell it when to shift from "Lo" boost to "Hi" boost. There is a button on the unit that lets you easily choose which setting you want. GReddy also sells a "remote" for the Profec which mounts on the steering wheel. All you have to do is press the button on the remote to shift from low boost to high boost.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
