Wastegate question
Riceboy
55
Jan 25, 2004
LaPorte, Indiana
I have a TIAL SPORT wastegate ...external.. and there is a threaded hole at the top of it and i was wondering if i leave that open or do i put a fitting in it and run a line sumwhere? like 2 the B.O.V. and also there is a small inlet for a hose on the side do i run that 2 the inlet on the B.O.V?
i hav a few pics and thnx 4 any help :dsm:
selmerguy said:
hole on the side is a vaccum to the turbo or anywhere before the tb. the hole on top can be open or used with a boost controller.
So i can leave it open and itll b fine or run a fitting inthere and run a line to my intake? or just runa a boost controllr between the line from the wastegate to the intake?
thnx
Terry
selmerguy said:
i would not leave the side open but the top open is fine.
So can i run the hole on the side to my B.O.V which has a hole on the top there the same size?
Thnx
wow dude you need some instruction.
bov=====intake mani
side wastegate========vaccume before tb not the bov. you might have a port on the side fo your turbo. i had to tap a hole in the charge pipe.
bov=====intake mani
ya dude you need to research a whole lot more before you try and install this turbo, we dont want to see you screw anything up. here read these http://home.bendcable.com/optimuspeterson/hrc_instructions.htm and search until your eyes bleed on here and 2gnt.com :thumb:
