Wastegate with no MBC
miclo16
May 10, 2010
goldsboro, North Carolina
Alright i got another question i've been searching around and basically if you could just correct me, it isn't necessary to have a mbc you could just run a line from the bottom of the wastegate to your compressor housing? is that right? thanks for your info:confused:
That is correct. Running it that way will make it so you can only run waste gate pressure. A MBC is so that you can run higher boost levels with out change the wastegate/wastegate spring
So the way it connects is through the bottom tee of the wastegate to the compressor housing?(oh and i got an external wastegate with a tee on the top and bottom, i would just leave the one on top alone?)
Just a friendly reminder, make sure your wastegate spring is 8lbs or less, depending on your fuel setup. I only make this point, because some wastegates come with 10, 12, and 14lb springs and I wouldn't want you to get your build done and blow something.
Don't worry it's inly a seven pounder or maybe 5 ill have to check with seller again
