wastegate springs
99 gst spyder
522
Jul 12, 2007
st. paul, Minnesota
mod in profile.
i want to put a mbc in my car, but a freind said i have to adjust my wastegate spring by turning the nut. my wastegate spring is set to about 10 psi (i think), and he said that if i were to put in the mbc, i wouldn't be able to go past 10 psi which i'd like to go up to about 16-18 psi. would that matter?...or can i just hook the mbc and adjust the mbc then go to 18 psi of boost?
Spring sets the minimum. With a MBC, you'll be able to go over that. That's what they are for :D
If your's is adjustable, then yes, that's the way it would go. You will run out of spring tensioning ability at some boost level and will need a new spring though, that's why MBC's are rad.
