Wastegate spring
NICKYTALON
46
Oct 3, 2002
hello i have a turbonetics wastegate with a 10lb spring
i searched and cannot find a bigger spring
does anyone know where i can buy a spring for a newgen wg
or if a tial spring will fit?
this is for a newgen wastegate
I believe that the Tial 38mm springs were interchangeable with the older Turbonetics 'Deltagate'.
Because the Newgen is a newer compact design, I'm not sure if the Tial springs will still work.
However, these are the part numbers for the available springs for the Newgen. Try searching for em on the net...you should find them!
(Summit carries them...but kinda pricey? Might find em cheaper elsewhere)
Wastegate Springs
5 psi-30693-5 (Yellow)
8 psi - 30693-8 (Orange)
11 psi - 30693-11 (Red)
15 psi - 30693-15 (Pink)
Good luck!
Springs for Tial are all the same/ not sure for 35mm only and don't know if exists any more/
They only give you different PSI. The smaller the WG/like 38mm/, the bigger the PSI's are. The new V-60 makes exception.
Example Large and small BLUE springs,38mm WG 23+PSI; 44-46mm 20+ PSI.
