wastegate fluttering
Spool'n Spyder
119
Feb 2, 2005
West Monroe, Louisiana
Ok I found a boost leak on my wastegate so I too kit apart and put a new gasket there. When I put it back together I pointed the vaccum nipple the wrong way and I didnt have time to fix it right then. When I drove it,I noticede it flutterd at full boost. I could tell it was the wastegate cause I could hear it through my external dump. I swapped the nipple back to the right placed and it fixed it. Then yesterday I hooked up my hallman and turned the boost up. The first 5 or 6 pulls were great then it started fluttering again so I hooked it back up straight to the wastegate and it is still fluttering. Anyone have any idea what is going on? I have searched everywhere it could not find anything.
Thanks, Nathan
Ok when I left work today, the first two times I boosted it did not flutter and then it did everytime after that till I got home. Please, I need help with this. This is a just broken in fully built 2.4 dohc with a 20g and cams. I was going to go to the track tomorrow night and see what it will run, but I cant if I cant get the bugs worked out.
Also, if anyone can give me a diagram of the nlts wiring for a keydiver chip I would be greatful. I think my 2 year old got ahold of mine and I cant find it. I tried the tmo link on dsmchips,com but it doesnt work. Anyways, thanks guys
Thanks, Nathan
Yeah, I think I can figure it out from that, thanks
About the wastegate, does anyone have a clue? Could my wastegate be going bad or is the spring bad or what?
Thanks
