Wanting to replace headunit and tweeters..
maxddr19
141
Mar 12, 2012
Martin, Tennessee
Well, I'm wanting to replace my tweeters but I don't know how to go about taking them out because I don't even know where they are. I'm wanting to get the rockford fosgate prime tweeters to replace the ones in there already. I don't have a stock radio because the person before me put in a kenwood radio. I don't know how to take that radio out. Do I need to take a side panel off to get to get? If so, then how do I do that without breaking anything?.... I plane on buying an alpine headunit also. Then I'm going to get RF back speakers.
To get the head unit out you will have to remove the center console and then the a/c face plate bezel above the head unit. After that take the side panels off and you can easily get to the back of the head unit to remove it....
as for the tweeters I would like to know how to remove them as well so I can replace mine.
Hm. Well I've already tried pulling out my center console once, and I cracked it a little bit, So I guess I was doing it the wrong way.
There is a screw under the cup holder and one in the rear on each side of the console. You will probably have to slide the seats forward to even see them.
There are no screws to the tweeters. Just lightly pry them with a flat head and unclip the connector.
The thing about them is that their size is odd. They are 3 inch tweeters, there are several threads about how to go about replacing them. Ebay is your friend here.
