Want some input on my log
olmytsi
3,079
20
Jan 29, 2004
Miami, Florida
Hey guys, I am tuning my car and id like some input on my log. I am running a 50 trim at 18psi with all supporting mods except a fuel pressure regulator. I would like to turn it up to 20 psi eventually but i want to get it right at 18 psi first. This is on 94 octane. I am tuning with an afc.
Just click it
http://members.aol.com/olmytdadon/18psi.gif
looks good. You are getting a little bit of knock in the High rpm and the low rpm but other than that it looks like a nice timing curve. You may be running a little bit rich in the high end and a little bit lean in the low end but it is not that bad at all. :thumb:
Thanx. I will richen up the low end where the o2s are below .98 and lean out the top end where the o2s were showing 1 volts.
also try to keep your timing as close to 15deg without going under...youll get the most power there
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
