LASER4G63T
- 91
- 0
- Apr 4, 2005
Fort Worth,
Texas
I looked around at idle surge threads, but mine isn't as described in most. My idle surges between 500-850 and sometimes at stoplights it hovers on 1000. Other times it is rock solid on 750...where i have it set. the stock boost gauge also moves with the rpms (nothing on the aftermarket). I looked at ICS threads and they all describe high (2K) rpm that i am not seeing.
Ok..so my UICP hisses a little if I put my ear to the joint at the TB elbow and it does not stop if i tighten the hose. I am sure its the hose, not the TB. Could this be the problem, or is it in more likely the ICS problem? Thanks in advance.
