Walbro Install Question
xxShaneOmac
423
Jan 2, 2007
Everett, Washington
Im doing my walbro install,
And Im about to add the Walbro to the fuel pump assembly.
But Im stumped on how to re add the positive and negitve wires.
My old pump was a Denso 150lph, So it has little o clips that go on a screw and is held down with nuts on the + and - sides.
What kind of wireing or harness clip do i need to get the wires into the Walbro?
Thansk
Im sorry for not claifying
I have a 2g AWD Walbro No post.
But I guess I might not need the post if I get the harness, The one that didnt come with the package dang.
And when I put everything in the assembly it is way off, The screw dosnt line up beacuse my walbro is 1/2 size of the Denso that was in there.
AHHHH
Or Do I not put the pump in the normal way with the screw?
Do I just put it in with the filter faceing where the screw goes and use a zip tie to secure it????
for starters where did you get the pump from? i have a walbro 255lph in my 2g gsx which i bought from slowboy racing and it was a direct plug and play pump harness and all...i didn't have to deal with nuts or bolts when installing it. ;)
My Walbro had everything needed,
And my Fuel pump assembly has a wire harness w/ wires on it,
But beacuse I had a Denso 150 pump the wires hooked up to that pump witch uses to screws and little o connectors and nuts on top.
So some how i need to remove that harness or splice it to a Walbro [ oem? ] Wire harness so I can plug my walbro in..
This is what im thinking.
Ill take pictures when I get home.
anyone know anything?
anyone know where i can pick up the wire harness that connects to the walbro and has a + and a -
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
