Walbro 190
CrazyM
409
3
Jun 22, 2006
P.G., BC, Canada
This is just a piece of mind post. Just wanting to make sure that this fuel pump kit would be a 'direct bolt-on' part.
Fuel Pump
Thanks, and sorry!
EDIT: It states it is for AWD. I thought the actual pump\the way its held in is the same. I know AWD bolts in from top, FWD bolts in from underneath. But will the pump itself be direct for my FWD.
Yes it is a complete bolt on kit :thumb:
This is the Walbro 190 l/hr intank fuel pump for all 1st gen AWD Talon and Eclipse cars.
This pump is designed to support mild performance and stock replacment applications
yet remains a bolt-in unit
I read that. But as you just quoted. it says for all 1st gen AWD.....What I'm wanting to know is will this work for my FWD laser?
I almost did the same mistake. Was going to purchase a Walbro 190lhp fuel pump for a 1G AWD. I thought it'd bolt-on the same way, but then I realized there are two versions... One for AWD, and another for FWD.
Check out: EXTREME PSI : Your #1 Source for In Stock Performance Parts - Walbro 190 LPH with Install Kit: Mitsubishi Eclipse 90-94 FWDhttp://www.
[Like 97gstJosh pointed out]
and:
Mitsubishi Eclipse / Talon / DSM 1990-1994 FWD 190lph Fuel Pump
Both are at very comptetitive prices, way better than getting it from ebay.
I'm still unsure as to which of these buy, depends on how much the shipping for Puerto Rico is.
:dsm:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
