Walbro 190
PFC_CiarlilloM
234
May 22, 2011
Euclid, Ohio
So, long story short is that my fuel pump went and I figured I'd get the Walbro 190 since I plan on doing a build here shortly. I have a 95 Talon ESi w/ basic bolt-ons, and everything else stock.
My problem is that it runs really REALLY rich. I'm sure you guys could have guessed. I did some reading and found somewhere that without rewiring, the 190 doesnt flow that much more than stock. Anyways, I need some opinions. I was thinking of getting an AFPR but I am unsure how much work it takes to install (only 21 still learning how to work on cars) or just run rich until I rebuild.
Thanks,
Mike
Thanks for the fast response. Is the only way to trim it with an AFPR? I'm guessing it's too much flow for the ECU to compensate for.
I am guessing your fuel pressure regulator is being way over run because of the difference in pumps. I'd imagine the difference between a NT pump and a turbo pump and their regulators would be so great the regulator just can't keep a good AFR.
I can't say for sure for a NT, but in a turbo DSM application you would correct it with a FPR.
Anyway, like the previous user said I'd not run it while it's running rich and for the same reason.
Well not exactly a fpr will only control your fuel preasure you cannot over run your stock fpr on a 190.. A 255 needs a fpr most commonly. You need to probably run stock injectors until you get some way to trim it out.. like link or something.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
