Walboro 450 install dampener solution
willyp42
60
9
Sep 28, 2016
Windsor, ON, Canada
Hey everyone,
Just wondering what the normal fix is for the dampener that doesn’t fit the bottom of the new pump.
Thanks
You can get it to fit but it'll be tight and sit at a slight angle. Then tie the pump down to the hanger using a hose clamp or zip tie.
Make a mental note of where the stock pump sits height wise. Lose the rubber damper and support bracket. Cut the feed tube to appropriate length so the pump sits at the same height, slide the insulation sock over the pump, hose clamp the pump to the hangar and drop it in the tank.
