spyderdrifter
- 5,422
- 854
- Jul 11, 2009
Somewhere in,
Colorado
Looked through the forums and couldn't find an answer. I need to know if the stock cams from a galant vr4 will fit and run properly on a 7-bolt head.
Code:
turbo cams are turbo cams.....1g and 2g are the only real difference but even then its just in the cam gears...since the gear has the cam angle sensor in the intake side if i recall
I always thought it was a bad idea to use different cams in a different head due to the tolerances that were created on the cams/head from the mileage.
no not really. its the cam caps that you cannot swap.
also what year is the head (cam angle sensor) that you want to put the cams in... if its 95/96 you wont have any problems, if its 97+ its not gonna work because of the cam angle sensor unless you switch to a 1g CAS
EDIT:you answered my question before i finished asking it. if you have a 94 CAS then you have no issues.
