efrainz28
- 169
- 15
- May 27, 2008
Long Beach,
California
I found out today I suffer from crankwalk
. My story beings with a clicking sound coming from my timing belt
. I look a the harmonic balancer it was bad so replace it and I decided to replace every thing on that side which includes the water pump, timing belt, balance belt, power steering belt, alternator belt and gaskets. I thought that would fix the clicking sound. After all that work I took it to my mechanic to verify every thing was done correctly, I dont have a big ego. So, he put my car on the dyno and run a pull he notices some on the laptop (I have aem ems). I had a fuel cut because it was over boosting at 3000 rpm but I had it for a while(one more reason I took it to him). I had a bad wastegate but when I was idle it was losing crank position. He looked at me and told me the wastegate was bad
then he pause looked at the car turned around toward me said you have crankwalk sorry . I was like wtf WTF. So, I need help building a 6 bolt. I plan to make 600-700 but being realistic minimum 500hp. Want to buy part that can handle power range. The questions are: parts need to achieve my power goal? Can I use the parts I replaced on the 7 bolt to the 6 bolt?(waterpump,timing belt.etc..)What is needed to swap 6bolt in to a 2g? 2.0L, 2.3L, or 2.4L? Will the transmission work on the 6 bolt?
Everything happens for a reason. I wont let it get me down I have to get back up build it stronger, faster, reliable. My journey begins with help from the DSM community helping me with my build.
then he pause looked at the car turned around toward me said you have crankwalk sorry . I was like wtf WTF. So, I need help building a 6 bolt. I plan to make 600-700 but being realistic minimum 500hp. Want to buy part that can handle power range. The questions are: parts need to achieve my power goal? Can I use the parts I replaced on the 7 bolt to the 6 bolt?(waterpump,timing belt.etc..)What is needed to swap 6bolt in to a 2g? 2.0L, 2.3L, or 2.4L? Will the transmission work on the 6 bolt?Everything happens for a reason. I wont let it get me down I have to get back up build it stronger, faster, reliable. My journey begins with help from the DSM community helping me with my build.
