vibration
zachdeagle16
97
Nov 17, 2004
coosada, Alabama
I have a vibration that goes on every time i accelerate hard. i replaced both of the carrier bearings and it still does it. any ideas?
Well your wheels could be off balance which isnt to uncommon with the monkeys that work in the shops now days.
The front carrier bearing that holds the drivers side inbord axle could also be going out which again isnt to uncommon for a 5+ year old car.
You really should fill out the car profile so we know what you have.
I have a bent rim on the left rear and i found out that my rear ened is leaking could this have somthing to do with it. it is only leaking around the filler plug.
I'd say a bent rim would definitely cause a vibration.. think about it wheels are supposed to be round. Even if you take it somewhere to get it balanced it will still have a vibration, you can balance an egg but you cant make it round.
Start with the simplest thing first when you are working on something..
