rtp03
- 0
- May 5, 2003
I have a 92 talon AWD Turbo with 150K and no mods except a K & N filter. The car has a vibration in the steering wheel and floor in 5th gear at speeds over 60+ mph. Also there is a low pitched grinding type noise when on the gas. The shake becomes worse when on the throttle and lessens when let off. I have tried most everything to fix problem. The shake seems to smooth out a little at 80+ but still hear the grinding noise when on the gas.
Things I have replaced:
- New wheels and tires.
- Different tranny. Old one was shot but had the same problem when
before I replaced it.
- New carrier bearings on driveshaft.
- Front tie rod replaced.
- C/V Joints checked and are OK.
- Motor mount replaced. Others were checked.
What's Left??????
What's Left??????
