Very strange problem..
UndergroundR32
664
Jun 6, 2002
When I turn the car over.. The starter will keep cranking but I never hear any combustion. However, if I crank it so it turns over once or twice and do that a series of times, it will fire. Any idea why it fires when I just crank it over once and stop, then do it again and stop, but it won't fire if I steadily keep it cranking?
could be a bad frp. Mine went bad once and wouldnt crank if I held the key but if I spun it over to prime the fuel line and then try it again, it would start. It was bleeding off all the fuel pressure when it wasnt running and mine also started fine on the first try when it was already warm.
How did you diagnose it? You just tried replacing the regulator and it worked? I have a brand new SX fuel pressure regulator. LEss than 2000 miles on it, so I can't imagine why it would do that.
It started happening after I did my flywheel swap.. Could I have done something when I took the transmission out and put it back in that caused this?
Originally posted by Defiant
Check the timing belt. Sounds like it may be jumped.
Previous to this thread I posted another asking about that. I've done a number of wot pulls in 3rd and 4th gear since and my timing and everything else seems to be fine. I really doubt that I jumped a tooth, but how would I check? (noob question)
  • For sale 4G63 ARP 7 Bolt Head Studs
    ARP 7 Bolt Head Studs $65 + shipping & paypal fees* torqued onceYou must be registered to...
  • For sale 1g 1G OEM Knock Sensor ( great condition )
    1G OEM Knock Sensor $85 + shipping & paypal fees* sensor is in great conditionYou must be...
  • For sale 4G63 NEW ARP 4G63 Main Studs
    NEW ARP 4G63 Main Studs $50 + shipping & paypal fees* these are $81 onlineYou must be...
  • For sale 4G63 NEW Ferrea Competition Plus Intake Valves
    NEW Ferrea Competition Plus Intake Valves $140 + shipping & paypal fees* these are 8 Intake...
  • For sale 2g S90 Throttle Body
    - S90 Throttle Body, brand new. Purchased this month from STM. Comes with the FIAV block off...
    • Bedicine
