- Thread starter
- #26
mitsu29
- 207
- 2
- Mar 11, 2005
Northridge,
California
i thought if i got the walbro 190 i woudnt need an afpr???
You are correct, if you are referring to my post, I was more pointing out that a 3s pump doesn't need an afpr, as a 255 does.mitsu29 said:i thought if i got the walbro 190 i woudnt need an afpr???
Of course, if you upgrade the stock line from the filter to the fuel rail, you'll need an AFPR even with just a rewired stock pump (at least, that's what the SteveTek site implies).underradar92 said:You are correct, if you are referring to my post, I was more pointing out that a 3s pump doesn't need an afpr, as a 255 does.
Au contrare mon friere. My 3s pump IS hotwired & ALL lines, including the in tank interfaces and filter to rail are #6 & no overrun here. It is also quiet, even with a (relatively) quiet exhaust!larsrya8 said:Of course, if you upgrade the stock line from the filter to the fuel rail, you'll need an AFPR even with just a rewired stock pump (at least, that's what the SteveTek site implies).
Most tuning tools can help you try to tune out some of the overrun by adjusting your low-end airflow. It helps, but isn't a cure-all. An AFPR isn't really a "go-fast" item... it's purpose is to keep the car perfectly streetable (and to save you from fouling out spark plugs) as well as to pass emissions.
No.JayRolla said:Whould'nt you beable to get more fuel from the pump by turning up the fuel pressure?
mitsu29 said:Another quick question: Do the Greddy Fuel Injectors(660) fit in the factory fuel rail? Meaning are they just straight bolt on? Plug and play? Are the greddy injectors a good brand/quality?
4bangr said:yes greddy injectors fit in your factory fuel rail. they are made by denso, who makes your oe injectors. buying 550's is like buying evo 8 injectors. i would go bigger.
i would stay away from fic & rc & stick with denso. greddy's are private labeled by denso.
their are 2 walbro 255 pumps the regular & the high pressure. fyi. i would go with the supra tt denso pump rewired.
I take it you were a honda guy at one point?mitsu29 said:Ok so DSMLink is a Fuel Management system right? As i said i need to do the research on this thing can you send me a link for DSMLink? What exactly does it do? I was just gonna get the EManage and take it to my shop guy to get the car tuned then i would hopefull be done with that
4bangr said:i don't want to get this thread off topic, but imho they are poop.
tstkl said:I take it you were a honda guy at one point?
get off the greddy bandwagon, as they tend to have quality parts, but they are always overpriced. Their injectors are increadibly expensive, and not too many people use emanage, so you won't be able to get as much help as you would be able to with dsmlink.
mitsu29 said:ummm nope have never owned a honda in my short life (24years) so im not sure why you made that comment, and their injectors are at a comparable price but im looking to get the FIC<--not sure what company a guy who posted earlier recommended
anyways thanks guys for all the feedback ill post an update once i find the setup that works for me
thegchild04 said:When I first looked over this post, I too thought he was from a Honda background. Don't take it like we are disrespecting you. But you should definitely ditch the emanage; it really would suck if you needed help with that system around here. And he is right about the injectors. But I do understand the idea behind one brand name for everything you put on your car.
anyhow this is what i decided to go with:
mitsu29 said:ah ok its cool no worries and sorry i got a bit snappyanyhow this is what i decided to go with:
Fuel Pump: Walbro 190lph
Fuel Injectors: im a bit undecided here as i would like these from the FIC site http://www.fuelinjectorclinic.com/cart/mitsubishi.htm or the Greddy ones http://optionsauto.com/prodinfo.asp?number=TP-13500072 help me out here, are the FIC ones of good quality? thats all really thats holding me back if they are im going with the FIC ones that i linked 750cc or is that too big for my setup??
Fuel Management: (drum roll) DSMLink is what i have decided. I like to do things on my own and i have these wonderful forums WHEN which will be often i need help
