venom intake manifold
xxpedrozxx
Jan 6, 2006
pawtucket, Rhode Island
Hey guys,
my friend and I took out my stock manifold and decided to put a venom one in. The thing is we can't remember when the ECG valves vacuum hooks up to? Does it hoook up to the throttle? Also where does the heat thing goes too, the long plastic piece that goes acrossi n front of your engine.. Also I have a return fuel line, the aftermarket venom doesnt seem to have a palce to hook it up? Also there is a goldish metal line that comes from some regulator, it has a flange on with where 2 bolts connect, it was connected to the intake manfiold in the back, can i just tee it into the manifold also? Also theres a thick hose, it has green lettering and says ENGINE and then an arrow any idea where this goes?
Thanks
pictures would help, ive installed an obx with is identical to the venom i dont want to give you misinformation so if you could post some pics i could be way more helpful
