2G vehicle speed sensor (vss) wire locations
kcwiggs
May 2, 2008
Seven Hills, Ohio
hi guys, i have a 98 eclipse gst and am installing a navigation system. I need to tap into the vss wire. I have heard many locations on the forums underneath the dash and such. I would like to tap in somewhere quick and easy if possible. I heard that the wire can even be located behind the radio, or even under the drivers seat. I also heard the wire is yellow/white. I looked under the drivers seat and there is a yellow/black wire could this be it? If anyone has any ideas much help would be appreciated, thanks.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
