Where are my vehicle rpm wire,vehicle speed sensor,and handbrake switch located?
If your trying to splice into your ECU wiring harness, then its right behind your radio. But becareful that you splice into the correct wires. Just remove your side plastic panel and you should be able to have pretty decent access to the harness.
wow thanks alot so it acutally goes to the ECU and not the under the stering colum
thanks again
