vavle steams or turbo seals
darkstar5456
207
Feb 23, 2010
Mitchell, South Dakota
i dont really know which one it is but i am pretty sure it one of them. i bought a t25 turbo form here and i form what i have read i should have had it rebuild. it pull good and builds boost bit it blows smoke out of the exhaust bad when i boost.when i start it up it blows a little bit then stops.i also get some smoke form the exhaust manifold. so if any had any input would really help i am lost and a little. f*&^ing pissed:mad: as i had to take it off twice just to fix the leaks:ohdamn:. please some help!!!
p.s any know how to adjust pw belt its squeels bad when cold started thanks
If you are blowing smoke on boost or after a long on boost pull it is most likely the turbo seals. If you are getting smoke on startup or when getting on the gas after an extended period of idling it is most likely the valve stem seals. Good luck:thumb:
if the pw belt sequels its probably lose or worn undo the bolts a little to where you can get it sliding have a friend pull the pump back and tighten the 4 bolts if continues then either you pw pump is bad or water pump i doubt it or you just low on pw fluid.
