TSiWarrior
- 300
- 10
- Feb 17, 2005
Detroit,
Michigan
Show's tonight so fast help I hope
It electronicly died after a hard accell, then started again after I
stopped... that was werid
Starter ground cable if connected to battery will make the starter
only click (wont turn over... what the?)
It starts pretty hard, takes a while
Idle's at 2k even though I got the ajuster all the way in.
Car seems too fast for it's own good, to the point where I think something is wrong.
The datalogger never wants to work right either, I might need new software, suggestions?
2g obdII cable on a palm m100 I've got MMCD (wont work) and tunerstein.
Please help! I wanna drive it!
I could give you guys CEL's and maybe logs if tunerstein didnt suck so
horribly bad.
Will that poteiometer help? I've got a rheostat im unshure of the ohm
rating on it tho. What size do I need and which wire does it go on?
I did invert the wires on the ecu and double checked them, then I also
swapped the blue wires to the coil pack.
When on the gas the car runs like a champ, it's incredibly fast.
horribly bad.
