* valve tic
How loud is the clicking? Are you sure its in you valve train? If its a soft clicking it may just be your injectors...
Sure its not the lifter ticking? Its very common on these cars and most just ignore it as its not a serious problem. Search for lifter tick or knock.
Mine does it when I first crank it, but goes away after it warms up.
Exhaust crack.
LOL. Your replies always make me crack up. OP, most lifter tick goes away in higher rpms. Change your oil to something a little thicker and see if it still persists. YOu may have a bad bearing if it gets louder. Take a video if possible.
James :dsm::talon::laser:
I know that Glowshift sells a cool lil oil pressure sending unit that just screws onto where the oil filter does, then you filter onto it. makes installation pretty easy.
