Valve, springs,cams
90 Talon AWD
148
Aug 27, 2008
jonesville, North Carolina
Hey i just got mt short block done. I am getting ready to get the head done will it be ok if i get topline valves, brian crower springs and retainers and brian crower 272/272 cams will all of that work. Thanks
All of that will work together of course. The only thing you need to worry about is if your cams would need upgraded springs and retainers. 272's are not aggressive enough to make that necessary.
Check out the kiggley racing beehive springs they are awesome...and dont over pressure your valves like double springs.
Im not trying to talk bad about anybodies parts either but definatly not a big fan of BC cams either. If you can afford it i would recomend hks. i have seen alot of cheaper cam go way out when you try to degree them...and the hks are normally pretty close.
