Talyn
- 443
- 19
- Jun 10, 2012
Pittsburgh,
Pennsylvania
I want to get a pair of kelford high lift cams, and I'm wondering if anyone has installed a pair or has any idea how much valve clearance they leave? Or if anyone knows how much lift or clearance the stock cams have. Idk how I could possibly check for clearance without buying the cams, and don't want to buy them and find out I don't have enough clearance, mainly worried because I have ross pistons(idk if they have more or less clearance than stock for the valves) and my block is decked .005, also about to have the head milled, I will probably run a thicker HG to take up some of the removed material, as I know the machine limit between both block and head surface is only .008, and the head may very well exceed .003.
