Vacuum leaks cause REALLY hard starts?
Blu90GST
172
Sep 10, 2013
East Peoria, Illinois
I haven't got the car all back together yet because of the weather but I have been starting it just to check on it... Since I put a new head on I've had really hard starts. Meaning a minute or two of on and off cranking to get it to start. Would not having everything capped off yet cause this or am I looking at bigger problems?
So that could be my problem in itself? I figured it would make it harder but not 1+ minutes of cranking harder.
make sure you have the brake booster vacume port block off. this is one of you largest vacume leak.
I'm deleting most lines. I'm hoping to get to that and my oil change tomorrow. And hopefully she runs good than
Yeah. I already have my egr blocked off. Hoping to get my boost gauge and vacuum lines done tomorrow. Than I just need a coolant flush and a new throttle cable and I'm good to go
I accidentally ripped off my temp sensor wire when doing fmic piping. It took me around 5 mins to start my car some times running battery dry. Once started seemed to run fine. +1 on the temp sensor
