hard starts
zerby4
May 7, 2006
long pond, Pennsylvania
my car does not start that easy i loose my rpm tech . the rpm tech jumps up and down . if i take the computer out and put back in its fine . is that computer.
I would check the coil and also check the caps on your computer. If the computer smells like bad fish, then the caps (capacitors) are bad. If you can find another coil, strap that one in and see if that helps anything. Also, I'd check the cam angle sensor as well.
i put a coil in it help a little put it still had same problems the cap on the computer and some burn marks
zerby4, please put some effort into your grammar, spelling, punctuation and capitalization when posting in the tech forums.
