Resolved vaccum lines to thermostat housing? please help!
DSM "BISH"
241
Sep 10, 2008
Erlanger, Kentucky
I have a 1992 eagle talon with the 6-bolt 4g63t and there is a fitting that comes out of the thermostat housing and it has a yellow vaccum like fitting on it with two nipples. there are vaccum lines that come around to this and there are four lines. two connect to one black plastic vaccum fitting with one nipple coming off it and the other two do the same so can someone please show me witch group of hoses goes to what nipple on that thermostat housing fitting or does it matter which nipple it hooks up to?
thanks
It's called the "thermo valve" and if you're doing the vacuum line removal you don't need it. But if you want to keep it follow the Taboo link here and find your model of car i.e. are you 1g Federal or California etc and follow the diagram to see where all your lines hook up.
Taboo speed shop vacuum diagram and removal for 1g and 2g
Solution
thank you so much that is exactly what i am looking for and i got it all hooked up now correctly! thank you so much :thumb:
